PanelView 'security'
Aug 2002
Manchester
527
Hi
On a Keypad panelview, when you have the prompt to enter a password, if you press the enter key without entering anything, it lets you through.
Doesn't happen on a touchscreen model.
Any thoughts?
pp
thoughts...
I did a quick check with a touch only Panelview that has security enabled and found that if you have a "blank" password it will allow you access if you press the enter key. Once I put a character back as the password, access was denied.
Is it possible you have an "operator" specified with no password?
In Panelbuiler it does mention 0 - 12 characters as the limitation on the password.
Just a thought :unsure: Like you said, it may be different with keypad only vs. touch.
loosewire :eek:
pp
I had a similar problem a couple of years ago where a Panelview 600 would allow you through with no password and would block you if you entered any number including the correct password.
For some reason I had to change the Panelview for another P/V600 and everything worked OK.
The only difference was the original was a version 4.00 and the second was a version 4.20.
(Possibly we buy our stuff from the same guys)
Hope this helps
Peter
I am using a panelview 5310 with a compact logix 5069-l306er. Studio 5000. when ever a security code is entered i would like to know that security...
3,191
Good Morning, I'm after some help with setting up a PV+ to use the AD to authenticate against. I believe I'm close, but I'm stumbling at the last...
2,660
It seems like this should be so easy to do that maybe I'm missing something?? Is there a way to create a numeric input box but only allow the...
5,624
Hello. I have a PanelView Plus 6 600 (2711P-T6C20A8) and I currently have security configured on it. Are there security logs files that are...
2,419
We have a PV1000 (2711-T10C15) that had the backlight die. I did a simple upload of the application and downloaded it to our spare screen...
2,504
