PanelView Security
GregPLC
Oct 2002
Milwaukee, WI
342
I have a PanelView1000 in which I would like to secure one of the buttons on a screen. (ie. password prompt once a reset button is pressed). I know you can set up security on individual screens, but is there a way to just set up a password for a button? As far as I can tell there really isn't, other than maybe making a copy of the screen the button is on and really take the operator to another screen just like the previous one they were on. They would think they are still on the same screen, but really they wouldn't be. Any other ideas?
Thanks in advance,
Greg
Greg,
I've used "passwords" stored in the PLC. When the user enters the correct "password" (on some numeric input control) it effectively unlocks portions of code (that might run at the push of your button . . . ). The only real challenge was coming up with the logic to "log out" the user and re-enable the protection without it being a nuisance.
I have also used the "shadow screen" approach that you describe in at least one case.
Good luck,
Marc
Thanks for the response, I think I will use the "shadow screen" method. I just wanted to make sure there wasn't something I was missing, as I don't have a heap of experience with the PV product line.
Greg
I am using a panelview 5310 with a compact logix 5069-l306er. Studio 5000. when ever a security code is entered i would like to know that security...
3,172
Good Morning, I'm after some help with setting up a PV+ to use the AD to authenticate against. I believe I'm close, but I'm stumbling at the last...
2,653
It seems like this should be so easy to do that maybe I'm missing something?? Is there a way to create a numeric input box but only allow the...
5,585
Hello. I have a PanelView Plus 6 600 (2711P-T6C20A8) and I currently have security configured on it. Are there security logs files that are...
2,413
We have a PV1000 (2711-T10C15) that had the backlight die. I did a simple upload of the application and downloaded it to our spare screen...
2,501
