panelview550 firmware upgrade problem
wolf3000
Dec 2010
Hawley, PA
I have an older panelview 550 2711-B5A2 terminal with frn 1.07 firmware. I am attempting to do a firmware upgrade using the firmware files and upgrade utility on the PB32 ver 3.83.01 CD. The upgrade utility is attempting to install FRN V04.41 firmware using file M55BDH4.EXE from the PB32 CD. The upgrade fails with the terminal throwing error 25 (firmware mismatch).
My question is are old panelviews using 1.x firmware incompatible with later firmware releases? The 1.x firmware does not support alarm banners. Is there an older firmware version (maybe 2.x) that is compatible with this panelview and supports alarm banners? Where would i find 2.x and 3.x firmware to try out?
Dear team, I am trying to update the firmware of allenbradley panelview550 model 2711-K5A2 keypad type with previous firmware...
1,914
Hi guys. Just want to seek for some suggestion, I am having problem in communicating panelview 550 to my laptop so that I can upload the HMI...
1,034
I have 2 sister machines (builder from Germany closed years ago) that each has a SLC 5/04 and a Panelview 550 with a serial cable between them...
2,237
Dear friends, I need your advice for a fault occurred in my HMI Allen-Bradely (panelview550) model:CAT 2711-B5A2. This fault is an alarm says ...
1,719
Hello all, I am working on a project where I am converting SLC 5/04 PLCs to Compactlogix L32E. The existing panelviews are 2711-B5A8L1. I...
1,303
