Panelview550
vikkaraja
May 2004
37
Good Morning, This will be my first time trying to communicate with a HMI. I have a panelview 550 CAT 2711-B5A5 with a RS232 port. My question is what do I need as far as hardware like a cable to establish a communication using RSlink. I was told I should be able to communicate to this device with the followings that i have in my possession right now.... CAT1747-UIC. I tried and of corse it did not work for me. Please help. Thank you.
Hi Mickey thanks for the link. I tried it and guess what I see picture of the computer 1747-UIC and no panelview. What else am I missing or I am doing wrong.
If you can post a screen shot of your RSLinx configuration.
Tell us what cable your using between the UIC and the PV.
See Pic's below for examples.
Things to check: What comm port did the UIC take? See hi-lite on pictures. The cable is a straight thru cable. Pay close attention to the device type in RSLinx.
Good Morning Mickey,I am using a Allan Bradely Gray Cable with the following number AB96881501 from PV to CAT1747-UIC.And I am still seeing the seeing PV Icon on the screen.
I'm not familar with that cable number. Make sure its a straight thru cable. AB 2711-NC13 or any straight thru.
After that you might try a different station address in RSLinx. The PV will default to node 2 but it can be changed. Is this a new installation or existing? Do you have the PV's offline program to check its comm configuration or can you see the PV's configue screen?
Hi guys. Just want to seek for some suggestion, I am having problem in communicating panelview 550 to my laptop so that I can upload the HMI...
1,037
Dear team, I am trying to update the firmware of allenbradley panelview550 model 2711-K5A2 keypad type with previous firmware...
1,916
I have 2 sister machines (builder from Germany closed years ago) that each has a SLC 5/04 and a Panelview 550 with a serial cable between them...
2,238
Dear friends, I need your advice for a fault occurred in my HMI Allen-Bradely (panelview550) model:CAT 2711-B5A2. This fault is an alarm says ...
1,721
Hello all, I am working on a project where I am converting SLC 5/04 PLCs to Compactlogix L32E. The existing panelviews are 2711-B5A8L1. I...
1,305
