PanelViewPlus 1000 - Save Alarm History to File
You can put in a "Print Alarm History" button that will literally print to a USB printer, but not to a text file.
The only way I can think of to get a text file from the Alarm History is to use a USB memory device with an autorun Batch file onboard that copies the Alarm History log file off the terminal onto the memory stick.
You can then use the RSView Enterprise File Viewer utility to open up the Alarm Log and view it.
That utility is in the RA Knowledgebase, Article ID 33924.
Hello to the community, I am new to Rockwell and I have a small problem with a PvP1000(2711P). Some buttons in the same screen are not...
2,353
Hello, I have a PV+ 1000 that I am unable to access the config screen on. All I want to do is upload the .mer that is currently running. I tried...
21
4,985
PLC Members, I’m working with a PVPlus1000 which is currently flashed with firmware 4.0. Since it’s an older panelview it cannot be flashed to a...
1,722
Hello, Have same FTView 6 programmed application running on PV+ Firmware 3.1 HMI and running on PV+ Firmware 5.1 HMI. Both connect to ML1000...
1,615
Hello, Have a ML1000 communication via NET ENI module to a PanelView Plus 600 HMI running Ver3.1 firmware. In my FTView 6 I've created and on...
1,956
