Part # for Resistive / capaitive devices
rguimond
Jul 2009
Escuminac
666
Can anyone provide a part # for a suitable RC device to protect PLC outputs from damage when solenoid coil fields collapse? There must be a thousand installed in the plant, but I can't find a single one with a marking. They're blue, slightly smaller than a nickle.
The little blue things sound like MOVs to me.
As for RC suppressors, we use a lot of Electrocube devices. I'm not sure about the exact part numbers though.
You're right. I googled MOV after I read your reply. They look exactly like what I was referring to.
In your opinion, are these suitable for the intended purpose?
Install a reverse biased diode across the solenoid terminals( assuming a dc solenoid) provided that you do not invalidate the solenoid hazardous area certificate if it has one. I suppose that you could also connect the diode across the plc output for that matter.
Hello, I am still new to PLC programming and I just got this job two year out of school so I don’t remember much. I was given a task were I have...
182
Good morning crew! Ok my logic works but I am missing something. When the start button is pushed it should like the red light for 4sec then shut...
442
Hello: I need to buy one end-cap which was not provided by an ex-Rockwell distributor here. Since I do not know the part number I can't find it...
24
6,527
For a thermoset molder I am looking for a vision system that can monitor part removal from a mold. The mold temps can range anywhere from 300 to...
1,667
Long story short, I am creating a display to display an array of Strings from PLC [topic]VarStrA_RPHD.Desc[VarStrB] totally 100 strings...
1,412
