Passing Parameter File Values in a Parameter File
benaiahhenry
Sep 2011
Corning, NY
265
Hey Everyone,
I am using FactoryTalk View ME and I am trying to pass a value to be used as a parameter file into a screen via a parameter file and not having much luck. Is this possible? I've attached an image to help explain what I want to do.
When screen "Machine 1" is launched from "Main" it will be passed a parameter file. When "Settings" is launched from "Machine 1" I want to pass it a parameter file that is defined in the file that was passed from "Main" to "Machine 1."
Does anyone know of a way to do that?
Thanks,
-Benaiah
I think you should be able to use the same parameter file. Just include everything in the one file. The references in "Settings" would be higher reference numbers.
Keith
I think I see what you want, but I'm not sure that it's possible. I was reading up on parameter files recently for a different purpose, but as I recall they can only be used to modify or replace tag names. Since a parameter file name isn't a tag I don't think it will work. Have you tried it?
You could use a single parameter file, as Keith suggests, though I suspect you're trying to do nested popups. If you only want two layers deep, I'd probably just create a normal popup for each machine, and use paramenter files only on the last level, assuming that level has the most repetition.
I just tried doing this and I couldn't get it to work. The parameters defined when I went to "Machine 1" didn't seem to carry through to "Settings"
Have you tried it?
Yes, I tried doing it the way you would hope would work (Setting a parameter file name as a parameter in the file being passed in, and then using that parameter in the parameter file field of the next goto button, but as you suspected that didn't work.
Yup, thats essentially what I'm trying to do, though rather than popups they are full screens.
Looks like that is the approach I'm going to have to go with, I was hoping to avoid that, but it looks like the "optimal" solution doesn't really exist.
Thanks for all the suggestions everyone!
-Benaiah
I don't do much with me but you could always use a global object. Say if you have 10 machines create 10 buttons with hard links to "settings" "Param file"in you global object set their visibility to false. Then when you open the machine screen for example machine 1 use a parameter to show only the button for machine 1 using the visibility property.
I am on the road now but can mAke you a quick and dirty sample to test
Thanks labeledas, I got it working thanks for the idea!
Just so future people know how to make this work:
I tried just passing passing "#1=1" or #1=2" into the parameter file for machine 1 or machine 2, and using "{#1}=1 -> Visible" etc in the global object, but that didn't work. So what I ended up doing was creating a tag in each PLC called "MachineNumber" and setting that to something different in each PLC. Then when I passed in "#1=[PLC]MachineNumber" and then using the "{#1}=1" as the visibility condition it worked great.
Thanks again for all the help!
Is there anyway to pass a parameter file without using a Go To Screen button in FactoryTalk View ME? I am currently using multiple Go-To buttons...
1,656
Is there a way I can pass a string with spaces in the parameter file? I want to do something like this: #1=Water Makeup
14,823
Bear with me as I try to explain what I need to happen. I'm working with FTView SE 6. I have successfully created a screen that has multiple page...
4,151
I'm wondering if it is possible to pass a parameter to a macro. In this case, I've created some global objects and made them into a faceplace...
10,293
I inherited a project in which a ME application displays process measurements (temp, pressure, flow, etc) on a PanelView Plus display. The data...
515
