PCI I/O card (need advice)
Bitmaster
Apr 2002
Timisoara
This is not a PLC question, but I know that a lot of smart and experienced people hang around here, so I thought I'd give it a try :)
I'm working on a project that requires the automation of a locomotive simulator system. The actual simulator requires about 50 digital inputs and 50 digital outputs. Since I'm very familiar with programming on the PC, I was thinking to use a PCI Digital I/O card to interface with the simulator (something like NI PCI 6509 http://sine.ni.com/apps/we/nioc.vp?lang=US&cid=12919) and implement all the simulation logic in software.
Does anyone have any experience with these cards they might want to share ? Any advice ? Am I on the right track ?
It is my opinion....
The stability requirements of your system should dictate as to weather or not to us a PLC or a PC. PLCs are designed for a variety of environments, and are above all very stable. In general the do not have mysterious "crashes".
Another parent at my daughters school wondered why in the world I would use a PLC vs. PC based system. I asked him if he would bet his life on Windows NT, or a PLC system.
If the operation of your project isnt critical, and infrequent crashes wont have an adverse effect, than a PC may offer far more flexability, for less $$$ than a PLC & HMI system, etc..
In regards to the NI I/O cards. I have used some ISA cards from NI years ago. They worked out rather well. I assume the cards in the link are updates with more I/O density.
Good Luck with it . MIke
Stability is not an issue. If it crashes, just reboot and restart the training sequence...The system simply simulates a locomotive ****pit with all the lights and switches and is used for training / psychological evaluation of train drivers.
I also expect that the PC solution to be much cheaper than a PLC based solution.
Ok so your better off with a PC in your case.
Now you have to interface the lights and buttons to the PC.
Some PLC manufactures make equipment that will allow you to use a PLC base for I/O to be controled by the PC. Automationdirect.com supplys a variaty of these type of PC based system products.
Best regards, Mike
Sounds like a good plan to me, I would go with the digi I/O. Probably the cheapest solution.
BTW, what program are you going to use for the simulator? Or are you writing that yourself?
John
Hi, I`m looking for purchase a CP5611 (6GK1561-1AA01). Siemens has stopped selling it, only if you have already they can sell it as spare...
1,732
We are upgrading a Wonderware Intouch 7.0 SCADA system to Intouch 2014 R2. The current system runs on NT4 and uses wonderwares AB1748KT IO driver...
3,447
Hello guys, I've been given a huge task to accomplish, Basically I have to update our old Wintelligent View HMI computers to Wonderware for our...
3,318
I need to use an Advantech 8-ch Relay and 8-ch Isolated Digital Input PCI Card Model PCI-1761 with Twincat PLC. There is any way to do it...
1,432
Dear friend, I am looking for an Analog I/O pci card for computer, I want to have input signal from the field and send anolog output to...
2,225
