PCIS for A/B SLC 150?
That worked perfectly. Now, I am trying to print. I have a printer intalled on LPT1(25PIN) and when I tried the test page in windows it printed, but I cannot print out of PCIS. Any ideas??
Great!!! I knew if I keep guessing I would someday help someone :) that only took just over 2000 tries ;)
Can you print to a PDF file?... just another guess, but I have no idea as I have never printed it
Give it up...
I spent my whole attention span trying to print from within/outside of dosbox and never got her done. I even tried printing to file and it never came close to working.
After 7.2 minutes (my ADDD* limit) I decided to take mutliple screenshots to get an image of the ladder.
Pieace!
footnotes:
*Attention Divided Deficit Disorder.
It appears you were not giving all of your attention to this!:D
I've given up on printing for now. I can thumb it out on MSWorks Spreadsheet fast enough. Does anyone know if MS Visio has a ladder logic template?
If you could zip and attach the application files, I could open it here with PCIS. I would then convert it to a text based or document based file for you. Then, I would re-post it so that you could open it with Notepad or Wordpad. After doing that, you should be able to print it normally,(not going thru DOSBOX or PCIS).
I was able to do a pretty spiffy job in spreadsheet, nice address descriptions, database (sort of) and then saved as a PDF. How dow I convert to text from PCIS without doing it manually?
I would also to thank everyone and GIT for the help.There is just one thing, I cant get my laptop to talk to the slc 150. I have checked everything (I Think ) to be sure that it is not my laptop or settings for the serial port. My hand held programmer works with the plc and I have swaped cables as much as possible but still no luck. The asssembly of cable came with the slc in a cnc mill of the 1990 vintage. the cable is interface converter 1745-pcc and I assume that the cable adapter from a db 25 to db 9 cable is a factory item. I suspect this assembly is the problem. Thanks Mike'shop.
Hi Mike,
Are you using a USB adapter? if yes make sure that you have the correct com port set up in DosBox
Not a lot of time today... this is a procedure that I wrote and it may help www.plctrainer.net/DOSBOX.pdf
You can also give me a call... 5 min on the phone can replace a lot of emails
My procdures will work with my cables or AB's
Mark
I think geniusintraining is the best source for help. Also, I think there are posts on this site on how to build an adapter using a short-haul modem or a rs-232 to rs-422 convertor.
See this thread, post 5 & 6 for more info.
http://www.plctalk.net/qanda/showthread.php?t=4455&highlight=slc100
We have an old machine that has a SLC 150 in it and it went down with a fault today of no program. We have the pcis software on an old windows 95...
2,743
So being tired of turning on the old win98 laptop and running it to run PCIS software, I was able to get it to run on XP and communicate using...
38,559
Does anyone know if it is possible to force I/O's on an SLC 150 using the PCIS software without the handheld programmer? I have just begun on PLC...
2,825
Does anyone know where I can download or get my hands on a copy of pcis.exe I have a dead 150 and do not have a copy of the program??????????
8,731
Greetings. I am updating a SLC-150 program at our plant and I will utilize the few spare I/O pins and internal bits that are left. To accomplish...
3,701
