SLC 150 PCIS Help
Tim Ganz
Dec 2010
Dallas, Texas
689
We have an old machine that has a SLC 150 in it and it went down with a fault today of no program.
We have the pcis software on an old windows 95 laptop but when i open a file that has the machine name with a file extension of .100 pcis opens but it looks like a new file and i see no logic when I hit the F2 program development/ edit?
What am i doing wrong?
I am trying to do this offline and not connected to the plc. Does it even work that way?
I have many files with the same machine name and no dates so I have to look at the logic to see which one we need?
First I would try opening PCIS, then go to the folder with the file and open it from within PCIS - not try to have Windows open it. Sometimes programs don't respond to the prompt from Windows but they open to a blank screen.
From the main screen press F1, Then (I think it's F6) press the F# labelled Change Folder/Dir. Navigate to the folder with the file. Then press F1 or F2 (whichever is Read) then select the option that is Not SLC (Disk???) to select the file in that folder you need.
Going by memory now, as I don't have PCIS at home, so the numbers may be wrong.
+1 for what Aabeck said. Here is some additional info that may help. To navigate to a program after pressing F6, just backspace the existing folder name to erase it, then, type in the complete new folder name. There are times when changing menus that you will have to hit the "Enter" key to go forward and the "Esc" key to go back. I have also found these old DOS programs work best from either the c:\ (root folder) or its own folder directly in the root folder. Another thing, if you would like to zip and upload the .100 programs then I would be glad to look and see if there is any logic in them for you. I could also try to convert them to either a .txt or .pdf file for you to see.
Edit:
If you don't have or need a Manual for the PCIS software, here is a link.
Link:
http://www.plctrainer.net/PCISManual.pdf
Also, when you type in a folder name remember that PCIS is DOS based and folder "C:\PCIS Projects" will be "C:\PCIS P~1" (8 character maximum name)
Also I checked in PCIS and Read is F1 and the proper selection is Disk (now if only I could remember where I put that winning Powerball ticket)
I read that DOSBox can be used with PCIS software for Allen-Bradley SLC 150. Does anybody know where I can get a copy of PCIS software? I have a...
42
17,632
So being tired of turning on the old win98 laptop and running it to run PCIS software, I was able to get it to run on XP and communicate using...
38,562
Does anyone know if it is possible to force I/O's on an SLC 150 using the PCIS software without the handheld programmer? I have just begun on PLC...
2,825
Does anyone know where I can download or get my hands on a copy of pcis.exe I have a dead 150 and do not have a copy of the program??????????
8,733
Greetings. I am updating a SLC-150 program at our plant and I will utilize the few spare I/O pins and internal bits that are left. To accomplish...
3,701
