PCMK card to program S7-200, DL205
Dariusincj
Jul 2011
Missouri
43
The pins on my 9 pin d shell connector on programming laptop broke, years of programming. I have a PCMK card and wanted to know if anyone has every programmed a S7-200 and Direct Logic 205 PLC using the PCMK card and cable? I have the PPI-RS485 adapter for the S7-200 and I have the cables for the Directlogic plc. Anyone ever try connecting the PCMK cable to the PPI adapter and then to the S7-200? Same as for the DL205? Just trying to find a way around to program rather than buying a new motherboard.
The Dsub-9 connector on a 1784-PCM5 cable (for the 1784-PCMK Card) is an Allen-Bradley "Peer Communication Link", or Data Highway Plus network connector.
It is not an RS-232 serial port, despite having the same physical connector. You'll find a lot of that in the industrial world; see how many different serial and feedback connectors use the RJ45 that is most common commercially as Ethernet !
Hopefully somebody with PPI and DirectLogic serial driver experience will be able to weigh in on PCMCIA or USB/RS232 interfaces for those purposes.
Hi: Trying everything to get a DH+ connection to an old 5/15. I have an old laptop with a PCMK Series B card and a fresh XP installation. I...
424
Hello everyone! I have a problem connecting to plc5. I have an old 1784 PCMK card and a new industrial laptop with a PCMK card slot. The laptop...
5,074
Hey guys, I'm new here and somewhat new to controls. My three years of experience so far has strictly been with all new CompactLogix controlled...
2,103
Is there any advantage of using this type of of communication cable/card? If so, what are they?
1,907
Is the 1784-PCMK card still available? Trying to order a new one from AB and they are telling me I need a 1784-U2DHP data highway to USB interface.
3,667
