Pcmk card?
I can give you a lot of disadvantages. It won't run on a 64 bit machine. Even in a 32 bit emulator. It is not supported in recent OS versions. Unless you already have one, you are better off getting the USB based units out there. For DH485 there are a handful of super cheap adapters that work just fine. For DH+ there are a couple very expensive ones. If you need it you'll just have to shell out. I don't know anyone who ever used it to connect to RIO (including myself) so I can't comment much on that.
All this, and not to mention that the PCMCIA port is becoming just as hard to find as the 9 pin serial port on a PC. So much so that virtualization companies like VMWare don't even bother to support them.
I can't think of one advantage over the USB ones.
The disadvantages you mentioned are all true but I like the PCMK because it's smaller size and you get the DH+ and DH485 (and RIO for whatever reason) all in one compact package minus the flimsy cable connection. I was disappointed in the size of the USB's and the fact that AB separate out the DH+ and DH485. They should be able to to shrink these down to the size of a flash drive but I guess they're better than some of the old stuff like the KF2 and KF3.
No real advantages as Damian said.
The only thing I could think of would be having DH+ and 485 with the same card. Less to carry around. Although youll need the 2 cables.
Thanks for the reply. The reason I ask is I want to buy a spare cable for our SLC 500s and a couple of micro logix 1200s but the A/B price is $500.00.
It would be great to be able to use just a usb to connect to the lap top.
Do you have any recommendations on what cable to buy and what ever else I would need to just use the usb port on the lap top?
If your SLC-5/0x and MicroLogix controller serial ports are configured for DF1 Full Duplex protocol (which is the default) then you can use an inexpensive general-purpose USB/RS232 converter.
The one I use is the Keyspan USA-HS19. You'll find it's highly recommended here on the Forum.
If you need to use DH485 protocol on a serial port or network port, or if you need DH+ to the network port of an SLC-5/04, you will need a different device like the 1747-UIC or the 1784-U2DHP, or that old PCMK card and matching cable.
Hi: Trying everything to get a DH+ connection to an old 5/15. I have an old laptop with a PCMK Series B card and a fresh XP installation. I...
425
Hello everyone! I have a problem connecting to plc5. I have an old 1784 PCMK card and a new industrial laptop with a PCMK card slot. The laptop...
5,074
Hey guys, I'm new here and somewhat new to controls. My three years of experience so far has strictly been with all new CompactLogix controlled...
2,103
The pins on my 9 pin d shell connector on programming laptop broke, years of programming. I have a PCMK card and wanted to know if anyone has...
1,913
Is the 1784-PCMK card still available? Trying to order a new one from AB and they are telling me I need a 1784-U2DHP data highway to USB interface.
3,667
