PCS7 alarming problem
Apr 2003
Belgium
434
Is there someone who has experience with PCS7 ver 6? We've got some problems with alarming. Most of the alarms or coming in several times with a maximum of 1 sec time difference. We've upgraded our system from Version 4 directly to version 6.
Rudi
Fritz_frederix,
What brand and model of PLC are you asking about. Is it the Siemens S7 series? If so, there are many here with experience with that one.
I saw this problem with a very early PCS7 V4, but I've never heard of it occurring with V5 or later. Could it be something to do with the way the alarms have been programmed?
Maybe Siemens' original work around for the problem means that under some circumstances the programme cannot be carried directly from V4 to V5 or V6.
Does anyone have an example project of the cm ptp ET200 SP HA with 410-5H DCS (PCs7 9.1 SP1) for MODBUS MASTER/SLAVE communication ?
138
Hello, Is there a sequence when installing both TIA Portal and PCS7 in the same PC? First TIA and then PCS7 or viceversa? Thanks in advance.
494
Hello, I'm currently working on a project involving both PCS7 (v9.1 sp2 upd1) and a Panel Comfort system. This necessitates the use of TIA Portal...
817
I'm coming from a background of PLC ladderlogic/rockwell products. I am new to blocks. Can you point me in right right direction? What I would...
1,569
Hello everyone, i would like to read in pcs7 v8.2 the actual day of the month(ex 1 or 25 of the month) i used as attached read_CLK AND DT_DATE but...
1,944
