pcs7 drive es
sbz1971
Feb 2010
tehran
Dear All
I use Drive ES for PCS7 7.1 to control a Simoreg DC Drive via Profibus. There is a SIMO_DCM block in the CFC Library.
Which IO Pins of this Block should be connected to Control Word and Status Words of drive?
Thanks for your hints
Does anyone have an example project of the cm ptp ET200 SP HA with 410-5H DCS (PCs7 9.1 SP1) for MODBUS MASTER/SLAVE communication ?
144
Hello, Is there a sequence when installing both TIA Portal and PCS7 in the same PC? First TIA and then PCS7 or viceversa? Thanks in advance.
500
Hello, I'm currently working on a project involving both PCS7 (v9.1 sp2 upd1) and a Panel Comfort system. This necessitates the use of TIA Portal...
820
I'm coming from a background of PLC ladderlogic/rockwell products. I am new to blocks. Can you point me in right right direction? What I would...
1,571
Hello everyone, i would like to read in pcs7 v8.2 the actual day of the month(ex 1 or 25 of the month) i used as attached read_CLK AND DT_DATE but...
1,958
