Phoenix Connector Strain Relief
marv_tech
Apr 2022
East Coast
25
Hey all,
Another weird one. Long story short, I need to find a way to strain relief a phoenix/euroblock connector that will be getting a lot of in-out cycles (being used as part of a service procedure)
It is a 6 pin female phoenix connector on the cable. The cable it is attaching to is just 6 22-awg wires with adhesive-heatshrink at the moment. My current best idea is to file down an 8 pin connector on the pin side and use the screw terminals to clamp a wire loop, then somehow attach the wire loop to my cable.
Another thought I had was cutting some slots between the pins and looping some fine wire through that and then sandwiching with heatsrink on my cable, but this seems like a pain.
Any thoughts are welcome, thanks for your time.
There are euroblock connectors with a strain relief support, where you can just zip tie your cable.
But if you are going to plug and unplug it a lot, using something like a compact Harting/ILME connector, or even a basic M12 connector, you can have them in push to fit models would offer you a more robust solution.
The Phoenix terminal blocks are in place, and they accept a 10 AWG wire. Now, the customer wants to connect some 8 AWG wires (mechanical reasons...
5,612
I am stuck on fail ctrl error 1013 cannot get IP nor can do firmware update need help pls urgent
170
Hi, I'm working with a Phoenix Contact FL NAT 2304-2GC-2SFP Ethernet switch, I already set the IP address and it has been working fine. I can...
1,290
At my company, we are seeing massive failures of the Phoenix Uno power supply. This is a small 400-500v input and 24VDC output power supply. We...
518
Hi all, Historically i have used AB compactlogix exclusively working within the Logix/Studio5000 environment. I have decided to step out of my...
1,882
