Phoenix Uno Power Supply Failures
edd189
Oct 2023
USA
At my company, we are seeing massive failures of the Phoenix Uno power supply. This is a small 400-500v input and 24VDC output power supply. We connect it at 480V.
Within an installed base somewhere around 20,000 units, I would estimate we have had somewhere around 500 fail after being in service approximately 2-3 years. This seems low on the surface, but the failure rate is still well above the manufacturer's rated MTBF.
The issue internally is always a blown MOV.
Is anyone else using this unit? Are you experiencing failures?
Welcome to the forum! My understanding,MOV varistor is for surge protection. If it keeps on failing maybe your incoming power is dirty. It has been a while since I dealt with this kind of issue. I remember it is more common in some countries abroad such as India as opposed to the US. Ideas for improving power quality can be a noise filter of some kind or an isolation transformer
Have you spoke with your local Phoenix Contact technical support?
How much you take current out from power supply? If you have some kind of current peak in 24V side, try to change bigger current supply (t.ex Trio 5A, 2903153)
I have used Phoenix Contact power supplies about 10 years(Uno, Trio, Quint) and I have seen old working Phoenix contact power supplies from 90s. I have changed 0 Phoenix contact power supply. Most of the problems i have got with Murr and Schneider.
I am stuck on fail ctrl error 1013 cannot get IP nor can do firmware update need help pls urgent
170
Hi, I'm working with a Phoenix Contact FL NAT 2304-2GC-2SFP Ethernet switch, I already set the IP address and it has been working fine. I can...
1,288
Hi all, Historically i have used AB compactlogix exclusively working within the Logix/Studio5000 environment. I have decided to step out of my...
1,882
Hi all, first time poster and working on an existing PC TriSafe PLC for the first time for a project. I am wondering if anyone would know if...
1,115
(Rant)(CAD Models): Phoenix Contact Took the Time to say "FU!!" to their customers So obviously they have real CAD models of their parts because...
1,760
