Phoenix Contact Logic+ time adjustment for timers
sparkyinak
May 2016
Ketchikan, AK
79
Is it possible to adjust the time settings for timers while the process is running though the software or app? For example, I want to adjust a timer's timing while the process is running from 30 seconds to 25 seconds. It will be not detrimental to the process.
I figured it was a long shot being that it is not a common program. I'm new to the software myself. I have since figured out two things:
1. I have figured out how to adjust multiple timers with the same time and same over/lap at the same time but not when the programing running.... yet
2. A rework of the logic eliminated my need to adjust two timers at the same time.
However, if anyone is interested on how to set up multiple timers to be adjusted at the same time in Logic+, just howler
Thanx for at least looking and for this message board
The attached is part of the program that I am currently having an issue with. When the program run via the simulator. It works like it suppose to...
1,544
I am stuck on fail ctrl error 1013 cannot get IP nor can do firmware update need help pls urgent
173
Hi, I'm working with a Phoenix Contact FL NAT 2304-2GC-2SFP Ethernet switch, I already set the IP address and it has been working fine. I can...
1,299
Hi all, Historically i have used AB compactlogix exclusively working within the Logix/Studio5000 environment. I have decided to step out of my...
1,890
Hi all, first time poster and working on an existing PC TriSafe PLC for the first time for a project. I am wondering if anyone would know if...
1,118
