Photocell trouble shooting
xilog
Nov 2009
SE Michigan
21
Hello All,
We are trying to trace down a problem with a machine we have bought. The machine has two sets of photocells to prevent lateral movement of a stage if there is something blocking its travel.
The photocells are connected to a Telemechanique XPS-CEP safety relay, the photocells appear to function properly (i.e. the LEDs on the cells change color when blocked.
Does anyone know how to test the relay.
Solution
Hi Guys,
I think I found the problem. The alignment of the photocells was off. I haven't found any info about what the proper alignment should be, but after some trial and error, I was able to get the machine to start.
Anyone using a photocell to a DI? I mean the kind that looks at the light outdoors and turns on the lights at dusk. There are a ton out there...
3,441
Anyone know of a semi long range prox or photocell with a 4/20mA output? I need to detect the position of a object (plastic ball) in a tube, the...
4,088
After the new very nice update to this site I could not log in with my original password, tried to recover my account but did not recieve a email...
404
Hi everyone. I have an issue with an Allen Bradley PLC model 1769-L30ER. This PLC had a previous program with a different IP address but when I...
539
Hello, We are having trouble setting up a generic ethernet module for a Yaskawa GA80U4168 drive in RSLogix 5000 Version 20.01. All of the...
631
