picosoft software
roxusa
Nov 2008
NJ
994
Does anyone know how to download Picosoft software, I tried the AB site for the free download a dozen times and it gives me an error after I allow the Java to run but when I try the download it says there is something missing from the jar and it will not down load. I tried a 3rd part site but got only all their add ons and no Picosoft.
I just went to the Rockwell website & downloaded & installed version 6.22 of Picosoft without any problems.
Do I need to have a Tech support agreement, I logged in to AB.COM and tried again and the same thing. Once I enter my email and pass word, select picosoft 6.22
agree to end user agreement. allow Java to run. I get this error
"SECURITY EXCEPTION"
"missing required permission manifest attribute in main jar"
"http//download.rockwellautomation.complugins/rockwell.jar"
Yes, watch out they do not give you picosoft, If you say no to all the add ons you get nothing, if you take the add ons you still do not get picosoft software just a lot of pop up add malware that infects google chrome with a "managed exe that can not be deleted or turned off"
Ok, sorry, just ran across it with Google.
Edit:
Thanks JeffKiper, appreciate the help, didn't realize that site was a problem.
Hello, Im new to plc's and im trying to use picosoft to build a simple timer circuit that is controlled by input 01 , and as long as 01 is on the...
2,029
I'm new to picosoft. I've been working with it for a short time now and have been able to write a simple program that will turn 4 outputs on...
1,551
I have a series of solenoids I need to run on set time amounts as long as an input is closed. The problem I cant seem to nail down, is I only want...
1,275
Hello all, I am working on a simple program for an AB Pico PLC. Some info first: In the image below I01 is a ready signal from a machine. This...
5,911
I have a Picosoft controler that I am trying to use the counters in the ladder, but no matter what I do, the counter output shows on, even before...
2,054
