PID Help
PLCRugger
Apr 2003
22
It has been a long time since I've posted, and you guys were a lot of help then... I am back for more.
I am still working on a graduate project involving an AB1200 and temperature control. I have done a lot of research and received help to get me where I am now. Thanks!!! I finally have grasp on PID. 🍺
I have also revised my project. I still am trying to create a PID Temp control system for educational purposes but now even more basic.
I am using an AB Micrologix 1200, an analog module, a data logger to observe my results, a TC as my input, a resistor as my output, and a small plastic canister as my oven.
I have information on how to use the analog module and the TC to scale my input. My next step is to implement this into a PID function block. I have read the manual… and a lot of help that was… can anyone give me further assistance on building this function block and code to references to create the code I will need
Thanks,
Matt
Hello all, I have an issue with a PID block in RsLogix 5000. The parameters are P: 3.25 I: 0.11 D: 0.01 The Set Point is 71 psi This loop...
63
14,835
hey guys - I'm a novice PLC enthusiast, so this may be a simple one. I'm running a PID on a Micrologix 1200 PLC and I want to change the Gain for...
18
4,253
I need a little help with a project I have been thinking about. We have a belt line that is fed by a gravity door (pretty much a hydraulic...
2,742
Hi all, I have a request from client as follows, There's one PID for Control valve which would be controlling on basis of temperature. One...
1,524
Hi, I am trying to automatically regulate a process ( liquid ) in a tube using an ultrasonic sensor, differential level meter, control valve...
3,160
