pid tuning
I don't know what to put here
  • or here
    Votes: 3 75.0%
  • or here
    Votes: 1 25.0%
  • Total voters
ssullivan
May 2002
Need help tuning pid loops using RSLOGIX 500 with a micrologix 1200 precessor. Any rule of thumb advice on gain , reset , etc??:(
PID help
For starters, understand that Gain is the reciprocal of Proportioning Band expressed as percentage of range. Next, understand what "range" is: In SLC500 PID block, this is defined by "SETPOINT MIN" and "SETPOINT MAX" (an unfortunate misnomer). You also have to be careful to remember that all the data going into and out of this block is in 14-bit format, not the usual 15-bit. If you need PID basics, there's a great little book at simplesolvers.com. The A-B PID block is very powerful, but tricky to use.
Hello, I am attempting to tune a PID loop on a process. The process involves a valve with electronic actuator that has quite a high deadband...
2,199
so i have 4 25gpm wells feeding a 1000gal tank (T-1), with an additional 15gpm from a decant tank for 3hrs every 12hrs. P1 and P2 both controlled...
154
35,942
Hi everyone, yet another PID problem. I'm hoping I understand enough of the process I'm controlling that my request for help is reasonable. If a...
113
28,255
A few months ago, I started to look into PID controllers and the tuning of first order processes. This has, partly thanks to you, resulted in a...
162
62,648
I haven't had to tune a PID loop in a very long time. It's actually a PI loop for a pulse width modulation s.v. What was the name of that tuning...
4,122
