PID valve control
Mar 2012
El Segundo
Hi Guys,
Looking through this forum it seems I'm in the right place to ask this kind of questions because some of you have much more experience than me with PID control.
I have an AB ML1400 and a valve that I need to control with a PID loop. So far I know that the valve has a slow response time and to open it from 0% to 100% it would take about 6 sec. The requests in the valve control are to command the valve to open to 10% before to start the actual control, and very important, I need the CV variation to be really slow (can't accept fast variations of the CV).
The PV in my loop is very sensitive and seems to be an instantaneous value.
The way that I'm thinking to control it is to have a PID instruction in an STI interruption and to have some filter on the PV (about 4 or 5 sec low pass filter).
I not quite sure what would be an appropriate PID update time (time between interruptions) and I'm thinking to have something like 0.5 or 1sec. Would that be right?
To have a very slow variations of the CV probably very slow PI coefficients would help, along with some "deadband" settings.
One other thing I'm not sure is the "Feed Forward Bias" setting. Can this help me to open the valve to 10% and to start the control from here? If not may be somebody would help me to understand what is this for.
From AB documentation about the gains, Kc, Ti & Td it seems that the lower integral gain is the higher variable value, respectively 32767. So, when I setup my loop in order to have a low integral gain I need to have for Ti a value pretty close to 32767? I just need a confirmation for this to make sure not doing the right thing there.
I really appreciate your thoughts on this matter,
Adi
I thought that valve behavior is more important. Anyway the entire process involves the control of more PID loops, but so far, from what I've been told this is the loop most difficult to control.
Actually the valve control involves controlling the steam pressure to a turbine to maintain a certain level of generated power. So the PV is the system generated power (scaled to a maximum value) and CV the is the valve control.
My difficulty is somehow related also to the fact I don't have previous experience with AB PID and I'm trying to figure out what would be the right settings to start tuning with.
Thanks for your help.
Adi
Hi All, Has anyone any experience in controlling a non linear valve with a PID? Traditionally this valve is controlled on flow but would like to...
36
11,024
Hello, Would anyone have a tutorial or a good example of programing a PID controller for a I/P valve positioner ? Thanks
1,731
Second guessing myself here, need someone to either tell me I'm wrong or confirm that my thinking is correct please. I have an equal-percentage...
2,746
Hi guys, Need some help. Goal: Closed loop flow control of valve positioner to a flow value. Parts: I've got a K series Rotork valve with...
4,267
Good Morning, This may be an easy question for some...but I'll need a little guidance. I have a project where under a particular condition I...
1,609
