Pilz Safety Magnetic Door-Switchs to Siemens S7F CPU
erdemsvri
Jul 2009
Germany
172
Hello Everbody.
We are going to be performing a revamping project on an existing plant. In the mean time we are going to upgrade the "old" Pilz Safety System.
The change concept is to change old S7+Pilz controller mix to one S7F cpu and wire all the existing safety magnetic switches to ET200S modules with safety functionality. In old system they have used a "safety series connection" device from company Pilz (PSen i1) but I want to wire all the sensors directly 2 channels to Siemens F-DI input. I do not want to left any old device in the revamped electric cabinet. At this point I am doubting if it is possible from safety electronics point of view to wire the existing safety door switches from company Pilz to S7 because these are as stated magnetic door switches with (as far as I know) built in electronics not 2 channel dummy switches...
Attached is a picture from existing drawing and also you can find links to products here. I thought maybe somebody have already this experience and can help me whereas I am trying to reach information from Pilz and/or Siemens.
https://www.pilz.com/en-INT/eshop/0.../503221=PSEN-2.2p-21-PSEN2.2-20-LED-8mm-1unit
https://www.pilz.com/en-INT/eshop/0001000023701380G1/PNOZmulti-base-units/773100=PNOZ-m1p-base-unit
http://www.pilz.com/en-INT/gb/company/news/sub/products/articles/02030
http://www.pilz.com/downloads/open/PSEN_i1_Operating_Manual_20776-3FR-05.pdf
Thanks.
My plant is going through an upgrade, a 3rd party are proposing a PILZ programmable saftey system (not sure of model) which will have comms on...
2,165
I have a banner dual touch run bar (replacing an older dual palm button station) which I am trying to tie into a pilz safety relay (Pilz p2hz x3)...
2,809
I will be re-wiring a dual palm out station and replacing with 1 palm out PB. These two PB's are tied into a pilz x3 774350 start switch safety...
2,700
Does anyone have a link to the latest "Guide to Machinery Safety" from Pilz? I see many references to it online and they all say it can be...
4,910
Hi Guys, I'm trying to integrate Pilz Ethernet IP Module to ControlLogix. I added Pilz module as a Generic Ethernet module and I'm able to...
513
