PLC 1100 Alen Bradley
paiqi
Dec 2019
Kosovo
Firs I will Thank you all for let me to be part of this Forum.
My qyestion is :
I have a brand new PLC Alen Bradley 1100 and I have also USB adapter cable
My software installed are RSLinx Classic Lite and RSLogic Micro Starter Lite
One Time I was online but from now one I cant go online or connect PLC to Computer
Thank you so much for considering my Problem
Your image shows it is configured for com port 4.
You may want to verify that on your computer's Device Manager, whether the USB to RS232 connector still using that port, if not change accordingly in the RSLinx configuration tab
Help
I am using
Allen Bradley USB 1761-CBL-PM02 for All MicroLogix PLC communication
and also I checked the USB Port its same 4,
Still I am confused with RSLinx which type of driver I have to use , Because one time at drivers It was showing workstation " Alen Brandley PLC 1100 " when I hit at RSLogic comms icone Go Online.
but now is not going online anymore the PLC is Running Good the Red light came on in Cable but nothing on PLC
Did you watch the video?
1st configure RSLinx and use the DF1 driver and click on auto configure, it should pop up "Auto Configuration Successful" if it does not go no further and figure out way... if it does open RSlogix and select COMMS then System Comms then select the driver (DF1) that was "Successful" and then select "Go on line" or upload
Note until the driver is configured and save with the project you can not just select "go on line" you must use the COMS/SYSTEM COMS
Note until the driver is configured and save with the project you can not just select "go on line" you must use the COMS/SYSTEM COMS[/QUOTE
_____________________________________________________________
Brother if you can I will give you my teamviewer or my Whats up +37744215479 , I try to do that the USB is connected good port 4 durin auto configuration its showing fail
Thank you Thank you Guys for you Advise , now I am Online with the PLC was the drivers wrong . thank you Again
Hello, After searching the web a bit, I am still not quite sure how I should go about wiring up this controller. It is mostly built for 120V AC...
2,040
This is my first post on ANY forum and following the first private message I received I am posting this here so bear with me. I have been working...
4,044
Hello everyone I have a problem of losing the ip address of the micrologix 1100 and 1400 PLC each time I lose power. the problem is that I...
1,781
Hi All, Hopefully someone can give me an answer on this one. I need to communicate to a Micrologix PLC from Wonderware. Do you know if the...
4,141
Greetings, (My first post) I have a MicroLogix 1100 Processor. I have downloaded RSLinx Classic. I have also downloaded RSLogix micro English...
24
8,948
