PLC-2/15 Assistance Required - Willing to Pay
Your problem may be the input card itself. In our plant we have had many I/O cards grow oxidation on certain chips on the cards. This would get bad enough to short out the pins, usually intermittently. This mainly happens with older 8 bit cards with TI chips manufactured in Mylasia. In any case its possible for the Input or Output card to be the problem. Or as stated by another user, the Chassis itself. Also check the output, if its a 110vac card, check the blown fuse indicator.
Good Luck
It was the old 8 bit input module - light came on but the processor wasn't recognizing it. We figured this out after upgrading to a PLC-5 and going online. Maintenance tells me they had previously swapped the module, but they tell me so much stuff I don't know what is really true.
Of course, we had to go to a PLC-5 because maintenace also determined that the PLC-2 processor was bad so they ordered another before I could borrow our local distributor's laptop with the PLC-2 software. Well, in swapping the PLC-2 processor, they managed to fault the processor, loose the program, and break multiple pins off the EEPROM. The only electronic copy of the program was on tape at the machine supplier who was unable to read it. Coupled with the fact that we had no cables or software for the PLC-2, I bit the bullet and re-entered the program by hand into RSLogix 5.
At least now we are more capable of supporting this platform in house.
There is one other mechanical problem that is now being attributed to a maintance guy standing on some valves to replace a bearing before this all started. They are swapping valves now and hopefully this will get the machine back up.
I doubt I'll ever know the full story of what all happened before maintenance asked for help.
We're upgrading an old PLC-2 system programmed in ICOM. We have the files, the PLC logic is in a .LAD format. Does anyone have working...
425
Hi everyone, Im not after someone to do my task, I'm just after some guidance or even pointed to some online resources I may use to learn more. I...
29
8,184
Hi all, I have been tasked with a project involving a Modicon E984-275 PLC. I have, unfortunately never used this type of PLC before and would...
3,749
I am having major issues with writing a PLC program. I am taking an advanced PLC course at the local community college and this course is much...
8,910
Hi, I am taking a PLCs class toward an assoc. degree in MET. I am working on Exercise 7-18B in the Programmable Logic Controllers (third...
3,855
