PLC-5/40E - Cant write to N file
skyfox
Nov 2006
CA
279
I have set-up an integer data file "N50" with 100 elements. There is nothing being written to these locations from my logic. While on-line, I am attempting to write my own values in to these locations (Ie. 1, 2, 3, 4, 5 etc. etc.) by going in to the data table and double clicking on these elements. But the value reverts back to 0. How are my values getting overwritten and not saved in the data table?
I would like to have a table of my own integer data put in to a data table and have it available anytime the PLC is powered on. (Retentive data). How do I go about getting this done?
Confused!
Thx.
Right click the N file and click properties, see if it offers protection, set as constant if available. I think you may have to offline add the values and set it as contant though.
Thanks Rsdoran,
All the Read write options are selected. I even checked the SKIP when clearing unused memory option but still not working. No other options are available other than DEBUG check box.
Any ideas as to how to do this?
Is some place else writing to those locations? Are you absolutely positive nothing else is writing there?? Even as an indirect or as a MSG from another plc on the network??
Are you actually hitting the enter key after you type the number?
If you double click a file element and type a number, then click to another element, your entry is not made, and the computer display reverts back to the original value. You actually have to press the enter key.
Operaghost said:
Alaric, I was reading through this thread just thinking to myself "hit enter, hit enter, hit enter".
OG
You are absolutely correct. I was NOT hitting the ENTER key. Instead, I was clicking with the mouse.
Thank you.
And thanks to all of you for your help.
Hello Everyone, I am reaching out to this knowledgeable community with a peculiar problem I've been experiencing with a PLC 5/40E. This issue has...
2,305
Have a PLC5/40E that has a battery installed and a working battery warning light that is off with the battery plugged in. There is no memory...
2,749
Please help me! I need to perform the firmware update for PLC 5 1785-L20E / 1785-L40E and 1785-L80E, but I do not find these firmware to download...
2,416
I am trying to connect a PLC-5/40E to Ethernet via a 1761-NET-ENI. After reading several other forums and technical sheets I have connected the...
5,131
Hi, We have a PLC 5/40E (1785-L40E/F) which is not working. We do have others like PLC 5/40, 5/60 and a 5/80 in our stock. I like to know if I...
1,946
