PLC 5 Ethernet Processor with Phoenix Contact ILC 151 ETH
Mar 2013
Gurgaon
In our project, we want to send messages from PLC 5 Processor (Rockwell/ Allen Bradley) to our Phoenix Contact ILC 151 ETH. PLC 5 Processor is Ethernet (L40E). Also,ILC 151 ETH is Modbus TCP/IP Controller.
Pls suggest, whether it is possible for Ethernet PLC 5 to send messages to Phoenix Contact Controller? Also, suggest how? Any Gateway...
It doesn't look like the Phoenix unit supports Ethernet IP. Even if it did you'd have to check the series and revision of the PLC-5 to see if it supported Ethernet IP.
Good luck,
(8{)} :) .)
(Yosi)
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
92
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
455
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
514
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
148
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
253
