PLC 5 MSG with an integer
Shivan
Jun 2009
New zealand
Hi Guys
I have a plc 5/40 that i need to message to another plc 5. Easy as, but i have no MG Data file for control, and i cant stop the plc to add one as it controls key parts of our 24 7 plant.
I know the i can use an integer but i dont know which bit is which. Does anyone have a list of what the integer bits do when used as MSG control?
Thanks in Advance
The first word of the N block contains the control flags.
If I remember correctly the bits are as follows:
12: Error
13: Done
15: Enable
Good Luck,
(8{)} :) .)
(Yosi)
Also, use the F1 key on your keyboard with the instruction highlighted to get context sensitive help. The control block layout is contained in the help files foe the MSG instruction.
I have a network with 4 PLCs PLC1 is controllogix and PLCs 2-4 are compactlogix and they all need to communicate. The current way I have this...
279
Hello All, is there any way to fetch remote controllers Mode Run/Remote Prog/Faulted etc. ( AB L8 Series) using CIP message, if yes please share...
834
Hello all. Working on a centrifuge for a customer. They have ACS880 ABB Vfd's installed, and need them to talk VIA the FENA card Ethernet to...
1,358
We have many sites with PLC-5s and 1785-ENET sidecars that are being pounded pretty hard by the GE IGS driver (Kepware) and iFIX/Historian...
994
Hello: Working on a program that needs to read some data from other Rockwell PLCs. Every second my program sends "CIP Data Table Read" command and...
30
7,010
