plc analog inputs & outputs
Mar 2012
bangalore
19
The PLC having a analog inputs/outputs to control the machine....
Analog inputs/outputs means a sinusoidal signals take to the PLC.
but PLC don't take a RESOLVER signals...? Resolvers also generate a sinusoidal signal......what is analog means exactly...
thanks for ur help....
Analog inputs/outputs means a sinusoidal signals take to the PLC, but PLC don't take a RESOLVER signals...? Resolvers also generate a sinusoidal signal......What does analog mean exactly?
I think the best way to think of PLC signals is to compare the analog signals with the other big PLC category, digital. Analog signals vary in signal strength from 0 to maximum, where digital signals are binary - they are either a solid ON signal level, or a solid OFF signal level.
Analog signal is a signal that contains information using no quantized variances in frequency and amplitude. In other words, an analog signal contains information that can vary over a wide range of values, where a digital signal is quantized for (usually) two values, ON and OFF.
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
245
Hello, I was wondering if you guys could help explain to me how the wiring and signal on Digital and Analog inputs/outputs run from the PLC to the...
2,681
Hello all, I am a recent graduate at my first job tasked with a PLC project. I need to control a linear actuator given feedback from several...
2,158
hello everybody. MY plc is cpm1 20cdr-a(omron). i m using this plc and i m facing problems related to: 1- i have moisture sensor(analog input)...
4,356
I'm trying to hijack a laser's analog signal from a Modicon to a CLX5000. I ran the wires and did the hook up as normal parallelling in with the...
17,475
