PLC analog wiring
Donquest
Aug 2015
Nigeria
I am conversant with PLC digital input connections and ladder logic, However,I'd like to know how PLC analog inputs and outputs are wired. What are 4-20mA and 0-10v? Do they have anything to do with the wiring?
Depends on the analog card(module) you have. And the analog device itself.
Can you tell us? Complete catalog number(s).
Hi, Do we need to use shielded cable from TB to IO card. In my case cables coming from field is connected to a surge protector and then to a HART...
1,380
Have a question about what others on this site think is the best pratice when wiring analog inputs and outputs. Have a project where I will be...
16,022
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
258
Hi all, I’m an electrician with limited knowledge of PLC circuits. Typically I will see simple 2/3/4 wire terminations for transmitters on...
26
1,295
Hi all, I want to catch min piks of an analog signal when digital signal is on(pls see the attached oscillogram). My hardware is 5069-L306ER CPU...
1,017
