plc battery cartridge
johneedw
Oct 2009
asia
204
Hello friends,
I've a fault S7 200 PLC (CPU 216), i think that the battery cartrige might cause the fault because i've reload the project to the plc successfuly but the PLC still stop with SF red led ON !.. Please, advice me to the way to replace the cartige with a similar one from another machine , i don't sure if i should remove the working one when the source machine is powered on or when it is shut down?!..waiting to hear from you..
I have swapped the battery both ways and it doesn't seem to be a problem. The battery takes over from the supercapacitor when it is discharged, so the safe way is to power up for 20mins to be sure the supercapacitor is charged, power off, swap the battery, then power back up.
But.... I haven't ever had a flat battery cause an S7-200 PLC fault, so I would be very sceptical that it is the cause of your problem.
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
251
Hello friends, The battery of my omron plc goes low and need to replace with a new one. The original battery value is 3v exactly, while I've a...
646
Hello, I am doing research project focused on the retrofit of a diesel locomotive into a hydrogen-fuel-cell-battery hybrid locomotive. The...
538
At the moment on my application (S7-1212C), the PLC/HMI are showing the correct time, i.e. the displayed time matches the time of the clock on the...
932
Hello Everyone, I have a Mitsubishi PLC FX3U According to Mitsubishi PLC manual we have to power off the plc and change the battery in 20...
1,736
