PlC Battery Change
atatari
Sep 2002
92
Hi there
We have different kinds of PLC in the plant AB,GE,IT,KOYO with different models for example our AB ones are: SLC 5/01 5/02 5/03 5/04
Micrologix and PLC5 and GE 90-30 series and junior.
My question is after how many years the PLC battery has to be changed? and what steps should be taken to change them? Is there any specific procedure?
Thanks,
First of all, make sure you have a backup copy of the code in at least 3 different places. We change our batteries on a yearly basis, whether they need it or not, because at 1:00AM, you really do not want that call to go and load a program after a power faliure.
I always try to change the batteries with the power on, this way there are not many risks.
I used to work for a distributor of PLCs, and I have personal experience of batteries lasting in excess of 8 years, and this on a PLC that was powered off 90% of the time.
However, I would never recommend waiting that long. Even at the prices they get for their batteries, I'd recommend changing them annually. It's cheap insurance when you consider how much one hour of downtime could cost you.
The fire department recommends you change the batteries in your smoke detectors annually. Change the batteries in your PLC at the same time.
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
245
Hello friends, The battery of my omron plc goes low and need to replace with a new one. The original battery value is 3v exactly, while I've a...
644
Hello, I am doing research project focused on the retrofit of a diesel locomotive into a hydrogen-fuel-cell-battery hybrid locomotive. The...
534
At the moment on my application (S7-1212C), the PLC/HMI are showing the correct time, i.e. the displayed time matches the time of the clock on the...
923
Hello Everyone, I have a Mitsubishi PLC FX3U According to Mitsubishi PLC manual we have to power off the plc and change the battery in 20...
1,732
