Dear,
I need a quick cost estimation for a PLC cabinet serving a well pump, it will be located underground, near the pumps, it will be wall mounted and connected to a fiber optic network using spliced patch panel.
it rating is specified to be IP65 and anti-corrosion. it will house the following item:
1- PLC, power supply, PLC software
2- communication modules
3- HMI
4- modem router with wireless antenna located outside the chamber
5- splicing patch panel
5- fan, lighting, outlet socket, breaker and terminals.
PLC and PLC components will be either schneider, siemens or allen bradley.
Panel should be similar to rittal.
other components will be from well proven vendors
i have estimated it to be 19000 dollars as supply only (installation and configuration and testing/commissioning i will multiply by 1.3), kindly advice about the estimated price.
thank you!
charbel
3- HMI
thank you!
charbel
