PLC connection wz 2 wire Transmitter
Amr Muhammed
Jun 2007
cairo
26
Hi all of you....
I faced a prob
lem in the site that i had to change connection between analog input 16 channel and flow transmitter 2 wire so i tried to connect it and but i found that all 16 channel read the same readings ...how to update the connection to be able to read every channel
thank you
B.R
As a mininmum you need to tell us the brand and type of PLC and Input card.
Then we need to know if its voltage or current and how they are wired a drawing would be the best help.
With more info you get alot more help
Hi all I did a quick search and couldn't find this specifically. I always buy 3 wire 24vdc proximity's and wire them (fused terminal) direct to my...
4,669
Hi all of you.... I faced a problem in the site that i had to change connection between analog input 16 channel and flow transmitter 2 wire so i...
3,678
I have got an Rockwell PLC 1769-L36ERMS . I have assigned a IP address to it . But every-time I Reboot the PLC it looses Communication to my PC...
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
323
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
457
