PLC connection wz 2 wire Transmitter
Amr Muhammed
Jun 2007
cairo
26
Hi all of you....
I faced a prob
lem in the site that i had to change connection between analog input 16 channel and flow transmitter 2 wire so i tried to connect it and but i found that all 16 channel read the same readings ...how to update the connection to be able to read every channel
thank you
B.R
As a mininmum you need to tell us the brand and type of PLC and Input card.
Then we need to know if its voltage or current and how they are wired a drawing would be the best help.
With more info you get alot more help
Hi all I did a quick search and couldn't find this specifically. I always buy 3 wire 24vdc proximity's and wire them (fused terminal) direct to my...
4,665
Hi all of you.... I faced a problem in the site that i had to change connection between analog input 16 channel and flow transmitter 2 wire so i...
3,672
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
312
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
454
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
253
