Plc connections
Go back to school - this is really basic stuff. AC and DC are totally different.
It seems like no one wanted to answer the original question...
The main "difference" is that in a typical operation, you should have no current flowing into your AC neutral while all the current is flowing into your 0VDC ground.
Depending on your circuit these may be connected, but it's definitely not common practice. It's something that you should avoid unless you fully understand the circuit as well as what you're doing with it. In the case of a "basic" full bridge rectifier, the neutral on the AC side is separated by a diode from the DC ground; therefore there is a voltage drop there.
As far as making that connection to a PLC, I would highly discourage it. A typical panel design will have a 110VAC (or 220VAC) section which will have your phase and neutral buses. The phase/neutral would go into a 24VDC power supply which would then feed a separate 24VDC/0VDC terminals.
Is there a particular need as to why you'd want to connect these two?
Hope that helps...
Vlad
Whilst you are all feeling like 'smarty pants', look at the drawing and tell me what is the difference. Bob will complain that he never grounds his power supplies, but the question is about 0V AC and 0V DC, not a floating AC or floating DC. If you have a floating system you don't ever have a 0V.
So in theory the two 0Vs are the same, but.... earth wires and connectors have resistance and there will always be a volt difference between the two 0Vs, so it is much better to keep AC 0V and DC 0V separate and don't use one for the other.
Hi, Have a very newbie question but needed some help. I have a Delta DVP-14SS and I was trying to find out the name and where I can get the...
1,225
Hey all, We are trying to interface a CompactLogix L35E with a Parker 590 DC Drive. My main question is, can we connect the common from the VFD...
2,210
Can any body tell me how to connect both analog & Digital I/P & O/P's modules through PLC. If you have any diagram plz attach it... Actually i...
2,914
Is it possible in WinCC to connect to a plc via 2 different networks? My situation is the following: i have 8 plc's (S7-300), each with two...
2,634
If one user is accessing the data from S7-200 PLC using the Invensys-Wonderware SIDirect DAServer; the PLC is not allowing the other users working...
3,436
