Unable to make multiple connections to Siemens S7-200 PLC
NFF
Mar 2010
Hyd
If one user is accessing the data from S7-200 PLC using the Invensys-Wonderware SIDirect DAServer; the PLC is not allowing the other users working from other nodes to access data using SIDitect DAServer. The PLC is allowing only one connection to it.
The connections are using Ethernet.
Any help to solve this will be greatly appreciated.
If you want more than one connection, I suggest you us an other PLC. This is one of the limitations of this type of PLCs. It comes together with the fact that it is cheaper than e.g. an S7-300.
Kind regards,
If you want to allow mutiple connections to the PLC you will need to configure additional connections in the ethernet card. The default is for only one connection to be configured.
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
246
I've posted this on the ptc forum as well, but no luck with an answer (waiting for my service contract number) I keep getting the following error...
126
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
122
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
86
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
140
