PLC flashing alarm light or output
zero1954
Oct 2002
MC Indiana
I am trying to make an A-B SLC 500 operate a solenoid which in turn operates a cylinder, and would like to get a flashing light when the cylinder does not fully extend after a specified time period, and the same light to stay on when it does extend fully and activate the prox switch. I need to do this with 5 different cylinders in the the same process. Any help would be appreciated, some spelling help wouldn't hurt me either. Ooooops, I am using RSLogix.
Many thanks,
Zero1954
Hi Kim,
Thanks very much for the info, I was doing that part of the ladder differently, but like your way a little better. The part I don't remember (I've been in production management the last 5 years) is how to make the out put flash on and off. I thought I had to use a counter in a sub-routine.
Thanks much,
zero1954
Zero, you might have missed one thing in Kim's post. The S:4/5 bit in kim's ladder example is flashed AUTOMATICALLY by the plc at a 50% duty cycle (i.e. on and off times are the same). As her description states, the rate on that bit is 640 msec (=0.64 sec).
The word at S:4 in the SLC status file is the free running clock in the processor. Basically it is a counter that is incremented by 1 every 10 msec automatically by the processor. The effect is that S:4/0 is on for 10 msec and then off for 10 msec then on etc... Due to the way binary counting works, each higher number bit is flashed on/off for double the time of the previous bit. So, S:4/1 is on for 20 msec, off for 20 msec. S:4/2 ... 40 msec on/40msec off.
The exact rate of flashing a light is not usually critical so using one of these built in flashing bits can save you time.
If you need a specific rate that does not line up with the "doubling" rates in the free running clock then you would need to create your own timer and logic to look at it.
Hello all! I have a 5069 -L310ers2 plc that has A1 and A2 Ethernet port. I connected to A1 port while flashing the plc and it was successful. The...
271
Hi All, I am new here , I am trying to flash AB plc 5380 safety guard logix Freeware 32.012 which is our program and old plc, but It does accept...
432
Hello everyone, I am having issues with an output module connected to my 5069-L306ER PLC. The modules I have connected are a 5069-IA16 in slot 1...
735
If I have some LED andon lights that are steady is it normally ok to use PLC logic to flash them? It's a red light that needs to be solid when...
3,366
Hi! I need one bit flashing on a PLC5 (AB)... For a SLC500 I used a system file bit that make it but for PLC5 I can't found anyone... I would...
6,219
