PLC Network (CANBUS)
Nick T-Com
Jul 2010
Washington, D.C.
I'm trying to set up a network of Sauer-Danfoss Plus +1 controllers (CANBUS), and I have to have numerous units very far apart from each other ( > 50' ). Are there any options for setting up a reliable network without using fiber optics. Are there any reliable repeaters that can be used. Ideally I would like to have a unit that consists of only the bus for the network, and the terminating resistors, so that I could have any unit turned off for maintenance, and it wouldn't affect the system negatively.
When I design Sauer Danfoss Plus1 systems I normally set the communication speed to 125Kbit/s and even if i have not had very long distances this should be no problem for hundreds of meters. Have a look at:
http://www.softing.com/home/en/indu...ng/practical-bus-length.php?navanchor=3010538
If you are in no hurry and have longer total distances then you can co for even lower communication speeds.
Just make sure to use proper shielded canbus cables and terminate correctly. If one node in the Plus1 CAN network dies this does not affect communication to the live nodes.
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
876
Hello All, IÂ’m starting a new project where the plc is connected throught LAN with external software which write some data on PLC db, obviously...
520
My customer wants me to set up their industrial computer hmi running factory talk view se client in the following way. They want to use a single...
1,039
Hello, folks. Looking for suggestions on network layout. I'm designing 3 stations with 6 pieces of conveyor on each. They are part of the same...
21
5,800
Has anyone ever encountered an issue where PLC's seem to lose connectivity momentarily, as well as all ethernet VFD's in different areas across...
18
4,039
