Plc point io module 1734-aent
nanomon
Dec 2015
New Jersry
I have a Remote 1734-AENT point io communication adapter connected to compact logix 1769-L32 processor through TCP IP Ethernet. Whenever there is a power failure or the module is restarted, the AENT Module's "Module Status & Network Status" indications are blinking Red-Green until I unplug the communication cable and insert back.
Is the module Faulty? or anything in the communication causing it. any Advises.
Thank you. How long this self test goes on. I think I waited atleast 15 minutes. But as soon as I do the Unplug & plug Communication cable, it works.
That's definitely not normal. It's possible you have a damaged or defective adapter, or there's something wrong with the network or switch.
Try connecting the module to a simple unmanaged switch with nothing else, then cycling power again. That will tell you if it's a conflict with another device on the network.
I have a bunch of tags in Historian/VantagePoint that off by one decimal point. I looked into the HMI displaying the same number, and the HMI is...
118
I have a robot cell controlled via PLC. I want to use an output from the PLC, based on whatever part number the cell is processing, to open a...
902
Hi, can anybody tell that how can we move floating point data from one Regiter to another register in Fatek PLC.?
1,553
Hello guys, i am taking a value from load cell module, i have to scale it so i want to divide it by 100 but the Wlsoft doesn't give me the...
4,324
Hello all, I have a FANUC robot running on a compactlogix PLC. All the physical IO is either going to the robot or through distributed IO modules...
1,402
