PLC Switch Types
Syranetic
Jun 2006
Waterloo, Ontario
I've been following a few tutorials on learning PLC, using namely LogixPro. I noticed on this particular piece of software (and tutorials) they reference different types of switches. I understand how to change the switch type, but I'm unfamiliar with the names or lingo of the different types.
As an example they say:
N.O. pushbuttons
N.C. Stop switch
I was curious if there was any kind of diagram or basic explanation anywhere for the different types of switches so I don't get confused to which type I should be using.
Thanks in advance.
PushButtons are momentary contact switches, the switching is active only while the pushbutton is depressed.
E-stops are typically push-pull maintained contact switches, once the switch is pushed, the switching will be maintained, until it is switched back by pulling on the mushroom head.
Toggle switches, rocker switches and the standard light switch are all maintained switches, the horn in your car is a momentary.
See this link: http://news.thomasnet.com/IMT/archives/2002/07/electrical_swit.html?t=archive
Hi everyone, I am working on a project to protect program memory on Omron CP series PLCs. there is several ways to write protection that i've...
643
Ok, I've setup comms to PLC's that are behind a NAT switch before, but I have not had a PLC behind one NAT switch communicate with a second PLC...
3,462
I am using Cscape 9.9 service pack 8. I am writing my program as a variable based program not register based. When I try and have the output...
850
OK. I guess I'm getting old and forgetful. Maybe someone can wake my brain up. I have a TopWorx Limit Switch P/N DXP-E20GNEB that has 2 P&F...
989
Hi Guys I hope you can help ! I need to monitor a pulley speed and disengage a clutch above a certain rpm and reengage it at low or at no speed...
1,712
