PLC5 analog input vibration value
Hani ahmed
Jul 2009
cairo
17
we have a problem with redundant processor PLC5 where there is analog input value be stable with the primary processor.
and at fault when working with the secondary processor the analog input value vibrate around it's real value where this vibration shown at HMI screen.
So we had to use rslogix5 compare tool to compare between the two application programs where the result indicated that the ladders are the same as shown in the attachment.
so could any please advise us why this vibration happens?
I would guess that it could be a problem with isolation or common grounding between the two analog input modules.
Are the Analgog Input modules the Isolated Analog Input Modules?
If not, then any specific analog input can only be "common" to one of the two analog moudles, and the connection to the other one could be unstable.
Hmmm....yes, that makes a difference. If the SAME input is showing up differently on two processors, it could be a timing issue - perhaps the secondary processor does not receive the signal at the same time as the primary processor.
I've got a 4-20ma pressure transducer connected to an analog card on an AB PLC5. Under the setup for the card, I have to set a raw minimum and...
7,385
Hi Guys, Im Re-writting a program from 6200 to RS Logix5k. Ive completed all the digital i/o's and logic that goes along with it. Now I just...
4,360
Has anyone ever calibrated an analog Input module for a PLC5? Was it worth the effort? I have a REV C 8 channel input module in a new project...
6,987
I'm trying to open the BTR/W Setup Screen for pre-existing BTR/W's in Logix5 and getting the warning "no module exist in I/O configuration". I...
6,150
I have an old PLC5 program with block transfers for many A/I cards. The "setup screens" won't come up because the modules were never added to the...
5,082
