plc5 scantime reset and record
remullis
Oct 2012
Georgia
179
I am needing to swap a L80 processor to a later series. I would like to reset the scan time and then record, and compare the difference between the old vs the new. I went into the processor status and then scan time but I am not sure how I would need to reset and then verify the scan time.
Second. I will be configuring the new processor with bootp. Where would I find the MAC address to know that I am clicking on the right device to configure. I see a SN # on this module that says SN 007D7D5E, but I dont see anything that specifies the MAC.
rm
In RSLogix just look at the Max value and record what you see. Then type a zero in that field and press enter. It will immediate update with the new Max value since it was last zeroed out. That's all you have to do.
And here is a picture of my L40E and where the label with the MAC address is located.
OG
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
158
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
374
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
526
Hello all, I am seeing this behaviour where an integer file (N46:33), has an integer in binary (11110) which is 30 in decimal. I did a...
522
