Pls recommend suitable logging way
ckchew666
Aug 2003
Malaysia
591
I'm working on a SLC5/04 for flow monitoring process which consists of a few flow transmitter (coriolis meter).
Everyday the operator will do proving (to run 2 transmitters in series to check their accuracy) anytime they wish on the transmitters.
At the end of proving a presentable proving report will be generated to shows how accurate the transmitters are. (Compare the reading between transmitter 1 & 2...etc).
This report has to be print out. Besides that, these reports has to be saved as backup for at least 3 months in the computer (RSView32).
What is the most suitable way to do it. I'm not good in VB :(
Most SCADA / HMI software will prepare reports and log data. I haven't used RSView, but I'd be very surprised if you can't do it in that package. I suspect some of the guys here can get you started. I also suggest calling on the Allen Bradley distributor for some help in getting started - that support is part of what you paid for when you purchased the software.
Hi im doing a energy saving program for a lamp. And basically the instructions are to turn off the lamp if is not being used ....... but with no...
1,488
Looking to get a program off of an older Eberle Vario P-621 PLC. I don't know much about Eberle, but some quick research brought up the idea of...
1,081
[IMG]https://www.img.in.th/image My timer cant run, please help me
3,264
Hi, I am fairly new to PLC programming and in this project i have to understand the electrical circuit and implement the logic in PLC. The only...
1,832
Hello All I have an older machine that has an existing Electro Cam PLS. I want to look to replace this system and add an encoder to capture the...
2,219
