Point IO Safety
DannyD303
Nov 2016
Hingham, MA
30
Good morning all,
I have Point IO Safety module that isn't turning on my outputs. In the code the coils are energized and the module is configured for safety and active but yet still no voltage at the card. One of the outputs is active but the other 3 are not.
Any ideas on what to look at would be helpful and just an fyi, I am using the same cards on other location for the same machine, configured the same and they work. I might be missing something simple but again, any ideas are welcome.
If there is a Sub Routine is there a RET function? Is there an MCR function? Iv'e been tripped up on both trying to trouble shoot.
Did you remember to configure the outputs in the module? That is usually my most common problem when this happens.
Go to module properties then the Output configuration tab and set the point mode.
Good advice, you need to also active the outputs in the card properties.
I have a Point IO safety chasis with some safety IO (1734-OBV2S cards in it). This is controlled by a GuardLogix PLC. I have two robots that I...
1,930
I have an existing Compact Gaurdlogix PLC with exising PointIO on it (Some safety and some standard). We will be adding a new panel with more...
3,351
Hi all, I just got back from looking at a project upgrade in the works that the manager is having his buddy do. It is using an L71S with Point...
1,814
Hi Gents, I am battling for a few days now an issue at one of my customer's site with a Guardlogix system. The System has the CPU's and three...
8,840
Hi All, I have a project coming up where I will be commissioning some safety point IO Details are as follows: 1756-L72S safety controller...
6,980
