Poll: Drawing size
Electrical drawings are always 11 x 17. I can't even imagine having to thumb through 24 x 36 prints when troubleshooting! :eek:
Panel layout varies depending on the size of the panel. Could be '11 x 17' or '24 x 36'. We design all of our own machines in house. Most of the time we build them too but we sometimes farm out the builds to machine builders when there are a lot of projects on our plate and time is a constraint.
We use Electra E9 for all schematics. AutoCAD for panel layout.
There isn't a "right" answer, but it has been thirty years since I did anything but 11x17.
When we drew and lettered by hand 24x36 (D-size) or even 36x48 (E-size) were required because you didn't have the resolution to get anything but simple stuff on 11x17 (B-size). Once CAD came into play and printers with good resolution were available there wasn't really any need to forgo the convenience and easy handling of 11x17. CAD could get as much useable info legibly presented on 11x17 as you could on 24x36 hand drawn.
Simpler stuff all gets done on Ansi(B). The larger wiring diagrams and schematics are done on Ansi(D). They're setup so that by printing a D print on B is half size so that its still readable. We usually print out full size prints for construction, but you can still read them half size for maintenance and troubleshooting.
D - (24 X 36 ) is the standard for electrical drawings
they can be printed fairly well as losw as 8.5 X 11 Letter
the larger format the better but sometimes the customer may require a certian size
i like to use 24 x 36 printed and then I supply the customer a PDF file at that formated the same size so they can print it on whatever paper they want
Maybe its an European thing, but its A4 for me, with all circuits broken down to small subsections and cross referenced, ie motor power circuit, safety circuits, I/O, Interfaces etc. this then forms a 'booklet' of drawings, saves having to drag a large sheet around with you.
A4 for me too. It is just a question of the font size not being too small.
Once was asked to bring along 2 sets of printed drawings for a machine. Turned out that it was in A3 and came as two huge "books". I had to buy a bigger suitcase just because of that.
Btw. when you use the smaller page size but with the bigger font and convert to PDF, the end result is that you can still view the diagrams on a mobile phone. I have stopped carrying diagrams with me outside the control room.
Apparently there are only two ways to present information, TurboUrpo's way and the wrong way.
I don't know about TurboUrpos way, but European way of using A4 size is much better here. đź““
It't like when doing the code, if you stuff too much in one page(/screen) u mess it up.
PS. this is end-user experience, end-users tend to use the drawings for years compared to short project of the integrator, oem or whatnot.
PSS. And naturally having them set-up properly with links as .pdf is just superior to any paper.
Most of the 11x17's I see are 2 columns, so it's just 2 8.5x11's next to each other...
I use 8.5x11 for my convenience, and as mentioned above, I can easily isolate 1 sub-system on a page, without wasting a lot of white space.
I don't do panel layouts, so I can see an obvious advantage to larger sheets for that.
I hate having to fold and unfold a page while crawling around inside a machine or panel, so I can find a wire or terminal. It seems there is always a component on a fold which gets destroyed over the years.
I do all the sheets on 1 file, and layer them by page, so you could print 2 pages on a 11x17 🍺
To me, there is not a “right” or “wrong” way to present drawings. It is all about specifications & preferences: your customer’s specs, your company’s specs, and finally your own personal preference.
What you need to turn over to the customer during the project submittal phase and at the end as part of the final documentation may be different from what you want to use during startup & commissioning.
Hi, Do you have any trick to make a software working when the 30 days demo version is expired? I've tried to uninstall/clean the registers etc...
295
I'm trying to use DTM browser to make make modbus poll from RTAC. I'm able to get the points in first poll object. But not able to get anything in...
127
Hello Guys, I have a Omron 3G3MX2 drive and I want to learn how its Modbus registers work by connecting to pc via Modbus poll software. does...
730
i am using modbus pol to trouble shoot a modbus comms issue. I have device communicating modbus over rs485 going through a lantronix express DR...
2,997
There are so many different ways to tackle the first sheet of the schematics. I've seen some people with a cover sheet, followed by several...
2,601
