Portable clamp on flow meter
1. I found several references that documented that orifice plates installed backwards always read low on the order of 10-35% from actual flow rate.
Heh.
I once saw an orifice plate so eroded/corroded on both sides there where radial gullies on both sides, and if you held it up to the light you could see pinholes where the gullies had met.
Flow is notoriously difficult to measure, anyone who believes an industrial (i.e. outside of a precision lab or test setup) measurement is better than 10-50% is making a bad judgement.
My dad and his colleagues at GE use to measure large steam turbine performance to better than a quarter percent accuracy; the key was that they did not need the flow nozzle measurement to get there, but instead inferred total flow from the process.
Thank Tom and danw. I'll be looking for a more suitable place to install downstream of the pump.
Hello, Does anyone know if there is a portable version of RSLinx Lite (even an old one)? I am wondering as I am trying to put together some tools...
688
Looking for recommendations for a small portable WIFI / Wired Hotspot box thing that I can use when travelling, sort of thing that will allow it...
4,913
Hi, Im looking for a solution i can add into the cabinet while commissioning to avoid having guys trip on cables and to have a small amount of...
2,245
I was wondering what others may use for a continuous flex cable for ethernet and some power / control signals. My application is for a small...
1,976
Hey folks, I'm looking for a portable desk/table that can be lugged around a plant for programming needs. Ideally it would be lighter, and be...
25
6,053
