On-site portable wireless
DwSoFt
Mar 2012
Alberta
960
Im looking for a solution i can add into the cabinet while commissioning to avoid having guys trip on cables and to have a small amount of mobility.
Im looking at this unit on amazon, heres the specs:
https://www.gl-inet.com/products/gl-ar750s/
couple things i will have to to add will be a 12/24vdc in - 5 volt out to power the unit.
The other thing is i want some serial support as well, i dont think it easily allows me to creat a tcp port of a usb serial device, the usb port looks like it is just for file server stuff. so im thinking i may just add a serial ethernet gateway to it, one that supports df1 and rslinx would be good like the Digione IAP. Thoughts? or other products with everything all in one?
I did browse the forum but only found old posts, speeds and distances are much better now on wifi than they used to...
I use a Ubquiti Rocket M5 with an omni antenna mounted on a tripod. It is POE, so there is only one cable from the cabinet. This works great for commissioning large areas where the M5 can be placed outdoors. For indoor commissioning, I just lay it on top of the panel.
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
92
When I connect to the site PLCS.NET is checking to see if the connection is secure. I click on a topic and it does it again. Click back and it...
20
1,270
Is there such a thing? I know you can electrically heat structures to keep them from freezing. But is there a way to cool a structure...
636
Hi all, i wanted to run this by everyone to see if has happened to anyone. we have multiple site edition applications running in the plant...
1,299
It takes forever to load and even refresh this site. Something has changed or what is going on? Not a browser issue, Firefox, edge, etc.
66
8,318
