Never seen any real trace cooling, only thing that I got involved with was the following:
Heat exchanger using cooling glycol, vacuum cooling where a vessel containing the product was cooled by creating a vacuum in the vessel, as the boiling point of a liquid lowers as the atmosferic pressure reduces it can actually take a liquid from say 100 Deg C to freezing, we used them to cool product at 90 Deg C to 4 Deg C. The only other thing I can think of is shell & tube (similar to herat exchanger) or perhaps not practical is peltier effect cooling where a layer of different metals can heat or cool depending on the direction of flow of a current, however, never seen it used in practice on an in-line pipeline only cooling electronics or used in a drywell calibrator, no idea if any company make such a cable for use in trace cooling..
