opposite of Trace Heating
mad4x4
Mar 2009
ST CYrus
363
Is there such a thing? I know you can electrically heat structures to keep them from freezing. But is there a way to cool a structure electrically .... Trace Cooling?
has it a fancy name?
Never seen any real trace cooling, only thing that I got involved with was the following:
Heat exchanger using cooling glycol, vacuum cooling where a vessel containing the product was cooled by creating a vacuum in the vessel, as the boiling point of a liquid lowers as the atmosferic pressure reduces it can actually take a liquid from say 100 Deg C to freezing, we used them to cool product at 90 Deg C to 4 Deg C. The only other thing I can think of is shell & tube (similar to herat exchanger) or perhaps not practical is peltier effect cooling where a layer of different metals can heat or cool depending on the direction of flow of a current, however, never seen it used in practice on an in-line pipeline only cooling electronics or used in a drywell calibrator, no idea if any company make such a cable for use in trace cooling..
I don't think it has a fancy name, but there are other ways than electrical to heat things.
Possibly long before electrical heat tracing there was steam tracing, which was convenient in plants that had utility steam. Look up steam traps.
So in principle doing as @parky mentions, i.e. wrapping a structure in thermally conducting tubing and passing a cool fluid through it, should not be outside some SI's scope.
Peltier (thermoelectric) cooling, again as @parky mentions, would be interesting. Google summat like "thermoelectric cooling for industrial enclosures," but Peltier is only about 1/4 the efficiency of conventional compression-cycle cooling.
Other refrigeration systems, such as ammonia-water, are another possibility.
yes I suppose it will depend on many factors, for example what temperatures will the cooling from/to, is this medium through a pipe, does it need to be along the whole length of the pipe, so many questions need to be answered first
From what I have read, freeboard (above the waterline) is a nautical term and the opposite is Design Draught (below the waterline), but is there a...
18
4,113
Good day, I've been browsing this forum for 2 years now, but this will be my first post. I have device with USB serial output. I would like to...
2,796
Installed 4 axis system, one of the drives (Kinetix 6000) runs a conveyor. Sometimes if the power is cycled and control restarted the conveyor...
1,979
Recently, I have experienced a surge in PMs. It is so much that I have to regularly empty my inbox in odrer to make space. What bugs me is that...
3,409
I want to make traces of variables in a Beckhoff IPC (that is not the engineering pc). Is it so that I should install the Twincat Scope server on...
457
